155
Reselecting row after updating it and clearing/reloading the grid with the UltraDataSource
I have a scenario in which users can select a row and click a button to open a pop-up with the information pertaining to that row as well as a couple of textboxes for editing (and then saving) new values. When data is saved the pop-up closes then focus returns to the main form which clears the ultraDataSource, sets the grid to the new cleared out data source. The datasource is then populated by looping through data received from a web service. The sort on the grid is then refreshed and the grid is in view. My first idea to reselect the last selected row was to use the following code...
 int lastSelected = 0;
if (ultraGrid.ActiveRow != null)
     lastSelected = ultraGrid.ActiveRow.ListIndex;
    // Reload/Refresh data here
   ultraGrid.ActiveRow  = ultraGrid.Rows[lastSelected];
This doesn't work however, because at this point index positions have shifted due to the refresh/re-sorting of data. Does anyone have any ideas as about how to do this?
  • 469350
    Verified Answer
    You would have to store some key information about the row, like the PrimaryKey or some identify field in the data source. Then loop through the rows and find the matching row.
