2325
How to use activity indicator?
We have a form that is used for display purposes and does not require any user intervention other than closing it.   I have a timer that fires off after the form is loaded to run a process that basically calls a stored proc that does some stuff on the database.  I would like to have the activity indicator to be active while this is happening.
In my constructor I have the following:
            ultraActivityIndicator1.AnimationEnabled = true;
            ultraActivityIndicator1.AnimationSpeed = 20;
I tried putting the code in the timer_tick event like this:
        void myTimer_Tick(object sender, EventArgs e)
            myTimer.Enabled = false;
            ultraActivityIndicator1.Start(true);
            ComputeServices();
            ultraActivityIndicator1.Stop();
            ultraActivityIndicator1.Visible = false;
            InitFormStuff();
However the indicator doesnt do anything... how do I get this to work?
thanks!
