Hi there,
there is a possibility the WinGrid with a line in VB to delete completely (content)?
Thank you Ronald
P. S. You have great products - I love it !!!!
Hello Ronald,
Thank you for your response. If my earlier post helped to answer your question, please verify it as an answer.
Thank you for your help
Best reguards
Ronald
Thank you for contacting Infragistics.
Are you referring to removing all rows and columns from the UltraGrid? If so, just set the DataSource property to Nothing. If you just want to remove all the rows, you will need to remove them from the bound DataSource and then the UltraGrid will update accordingly.
Please let me know if you have any other questions about this.
