870
Conditional formatting of values in summary rows
I have configured conditional formatting for the values in a grid (red on negative), however, this formatting does not apply to the row summaries (group by footers or grand total summary).
Is there a way to do this without a Draw Filter, and if not, can you provide the specifics of what to object type to check for in the GetPhasesToFilter and how to obtain the value in the summary row in the DrawElement method so the foreground color can be set there?
Dana
  • 469350
    Suggested Answer
    Hi Dana,
    That will work, but there is an easier way that does not require a DrawFilter:
     Private Sub UltraGrid1_SummaryValueChanged(sender As Object, e As Infragistics.Win.UltraWinGrid.SummaryValueChangedEventArgs) Handles UltraGrid1.SummaryValueChanged
            If (e.SummaryValue.Value < 0) Then
                e.SummaryValue.Appearance.ForeColor = Color.Red
            End If
        End Sub
  • 870
    Suggested Answer
    I have figured this out.  Here is the code:
    In the GetPhasesToFilter draw filter function:
    If (TypeOf (drawParams.Element) Is SummaryFooterUIElement) Then
       Return Infragistics.Win.DrawPhase.BeforeDrawForeground
    End If
    In the DrawElement draw filter function:
       If Not CType(drawParams.Element, SummaryFooterUIElement).GetContext Is Nothing Then
           Dim rows As RowsCollection = CType(CType(drawParams.Element, SummaryFooterUIElement).GetContext, RowsCollection)
           For Each summary As SummaryValue In rows.SummaryValues
              If summary.Value < 0 Then
                 summary.Appearance.ForeColor = Color.Red
              End If
           Next
       End If
    End If
