I'm developing a project for touchscreens and my users complain about the size of the scrollbars in the grid.
So I found that there is a solution of adding a UltraScrollBar to the UltraGrid, but I can't find how to do that! Is there an example somewhere? How can I attach the UltraScrollBar to the UltraWinGrid?
Thanks in advance.
If you want to change the size of the scrollbars, then that feature was added in v12.2.
private void ultraGrid1_InitializeLayout(object sender, Infragistics.Win.UltraWinGrid.InitializeLayoutEventArgs e) { e.Layout.ScrollBarLook.HorizontalScrollBarHeight = 100; e.Layout.ScrollBarLook.VerticalScrollBarWidth = 100; }
If you are using an older version than that, then it might be possible to use an UltraScrollbar outside the grid, but it would require a lot of coding.
Ok, but we are currently on a tight budget and not able to upgrade our infragistics product.
any other option? Is there an example on how to do that?
Hello Struski,
Thank you for contacting Infragistics.
I believe your best option would be to make sure you're using at least Infragistics 2013 Volume 2 and enable the touch support we added to our controls in that version.
http://help.infragistics.com/doc/WinForms/2014.1/CLR4.0/?page=Touch_Support.html
