I have got a column with DataType Boolean, so the values are displayed as Checkboxes.
Now I want to react to user input as the displayed Checkbox value changes to exit edit mode and process the change. I presume, normally the CellChange event should fire, but in my case it does not. Is that behavior well-known? Which event should I use instead, or how will I make CellChange fire on a checked change?
Best
Fr. Kunze
Hello ,
I am glad to hear that you were able to solve your issue. Please do not hesitate to contact with us if you have any further questions regarding this matter.
I solved my problem.
The CellChange event did react to keyboard input (space) correctly. In case of mouse clicks, the grid updated directly because i set SetUpdateModeOnCellChange() to True and did not fire the CellChange event.
