Private Sub UltraTextEditor4_EditorButtonClick(sender As Object, e As EditorButtonEventArgs) Handles UltraTextEditor4.EditorButtonClick If e.Button.Key = "chk" Then If UltraTextEditor4.Enabled = False Then UltraTextEditor4.Enabled = True Else UltraTextEditor4.Enabled = False End If End If End Sub
Once i click the check box , the whole ultratexteditor becomes disabled.
I am little confused.
The state button is for your own use. It's completely arbitrary and you can use it to track any state you like.Some people use it to indicate a null value. For example, in a DateTimeEditor, the user could check the checkbox to indicate a Null and uncheck it to set an actual date.
Disabling the control wouldn't be a good use case, since once the control is disabled, you wouldn't be able to click the checkbox to re-enable it.
I'm just exploring the components in ultratexteditor.
What I need is what can I do with stateeditorbutton in ultratexteditor.
Hello, Setting the editor's enabled property to false will disable the control. May I ask what you are trying to achieve by using the StateEditorButton with an UltraTextEditor? If it would help could you provide a mockup screenshot demonstrating your requirement?
