100
Text In Column Temporarily Dissapears.
I have an Ultra Grid with three visible columns.  The first column's style is set to 'Check Box' and is editable.  The second column is disabled and is a text column.  The third column is a text column and is editable.  When I click on the check box in the first column the text in the third column for that row dissapears until I leave the check box column.  So when the grid first appears, the first row is selected, the user sees all the data.  They then click on the checkbox in the first column and the text in the third column of that row dissapears.  Next they tab out of the checkbox column and the text appears again in the third column.  Any ideas as to how to stop the text from dissapearing?  Thanks...
Below is the code that is used to format the grid after it's been bound to the datasource.
Dim Band As UltraGridBand
Dim Column As UltraGridColumn
With Me.grdStep2Main
For Each Band In .DisplayLayout.Bands
    For Each Column In Band.Columns
        Column.Hidden = True
        Column.CellAppearance.ForeColorDisabled = System.Drawing.SystemColors.ControlText
    Next
    With Band.Columns(myReportTable.SelectedColumn.ToString)
        .Hidden = False
        .Header.Caption = "Select" '<TODO> localize
        .Header.VisiblePosition = 0
        .Style = ColumnStyle.CheckBox
        .CellActivation = Activation.AllowEdit
        .SortIndicator = SortIndicator.Descending
    End With
   With Band.Columns(myReportTable.CRMRptNameColumn.ToString)
        .Hidden = False
        .Header.Caption = "Report Name" '<TODO> localize
        .Header.VisiblePosition = 1
        .Style = ColumnStyle.Edit
        .CellActivation = Activation.Disabled
        .Width = 250
    End With
    With Band.Columns(myReportTable.CIMTabCapColumn.ToString)
        .Hidden = False
        .Header.Caption = "Tab Caption" '<TODO> localize
        .Header.VisiblePosition = 2
        .MaxLength = 15
    End With
    With Band.Columns(myReportTable.TabOrderColumn.ToString)
        .SortIndicator = SortIndicator.Ascending
    End With
Next
End With
  • 469350
         Are you using the latest hot fix? There was a bug like this recently where sometimes a cell would end up using the highlight forecolor instead of the normal forecolor, so it would appear with white text on a white background. But it was fixed a while ago.
        If you already have the latest hot fix, then I recommend reporting this issue to Infragistics Developer Support and including a small sample project that demonstrates the problem.
         Submit a Support Issue
