365
AfterDataNodesCollectionPopulated Fires For Scrollbar
We have an application that uses an UltraTree for user's to select specific nodes. The list is usually somewhat short, but we've had cases where this case is large enough to require a scrollbar. When this is the case, when the user clicks a node, we get this error:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentException: Can't access the 'Value' property when not in edit mode
at Infragistics.Win.EmbeddableEditorBase.get_Value()
at Infragistics.Win.EditorWithText.get_Value()
at OptiBreak.RunSelection.utReleases_Click(Object sender, EventArgs e) in c:\Jobs\Product\Opti\Opti-Break\OptiBreak\RunSelection.cs:line 568
at System.Windows.Forms.Control.OnClick(EventArgs e)
at Infragistics.Win.UltraControlBase.OnClick(EventArgs e)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.0.30319.34011 built by: FX45W81RTMGDR
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
Microsoft.VisualStudio.HostingProcess.Utilities
Assembly Version: 12.0.0.0
Win32 Version: 12.0.21005.1
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualStudio.HostingProcess.Utilities/12.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualStudio.HostingProcess.Utilities.dll
Win32 Version: 4.0.30319.33440 built by: FX45W81RTMREL
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System
Win32 Version: 4.0.30319.34003 built by: FX45W81RTMGDR
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
Microsoft.VisualStudio.HostingProcess.Utilities.Sync
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualStudio.HostingProcess.Utilities.Sync/12.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualStudio.HostingProcess.Utilities.Sync.dll
Microsoft.VisualStudio.Debugger.Runtime
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualStudio.Debugger.Runtime/12.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualStudio.Debugger.Runtime.dll
vshost32
CodeBase: file:///C:/Jobs/Product/Opti/Opti-Break/OptiBreak/bin/Debug/OptiBreak.vshost.exe
Infragistics2.Shared.v11.2
Assembly Version: 11.2.20112.2050
Win32 Version: 11.2.20112.2050
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Shared.v11.2/11.2.20112.2050__7dd5c3163f2cd0cb/Infragistics2.Shared.v11.2.dll
Infragistics2.Win.Misc.v11.2
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.Misc.v11.2/11.2.20112.2050__7dd5c3163f2cd0cb/Infragistics2.Win.Misc.v11.2.dll
Infragistics2.Win.UltraWinEditors.v11.2
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinEditors.v11.2/11.2.20112.2050__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinEditors.v11.2.dll
Infragistics2.Win.UltraWinGrid.v11.2
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinGrid.v11.2/11.2.20112.2050__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinGrid.v11.2.dll
Infragistics2.Win.UltraWinListView.v11.2
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinListView.v11.2/11.2.20112.2050__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinListView.v11.2.dll
Infragistics2.Win.UltraWinTabControl.v11.2
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinTabControl.v11.2/11.2.20112.2050__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinTabControl.v11.2.dll
Infragistics2.Win.UltraWinTree.v11.2
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinTree.v11.2/11.2.20112.2050__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinTree.v11.2.dll
Infragistics2.Win.v11.2
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.v11.2/11.2.20112.2050__7dd5c3163f2cd0cb/Infragistics2.Win.v11.2.dll
System.Core
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Data
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
System.Deployment
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Deployment/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Deployment.dll
System.Design
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Design/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Design.dll
System.DirectoryServices
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.DirectoryServices/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.DirectoryServices.dll
System.Runtime.Serialization.Formatters.Soap
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization.Formatters.Soap/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Runtime.Serialization.Formatters.Soap.dll
System.ServiceProcess
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceProcess/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.ServiceProcess.dll
System.Web
Win32 Version: 4.0.30319.34009 built by: FX45W81RTMGDR
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/System.Web/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.dll
System.Xml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
stdole
Assembly Version: 7.0.3300.0
Win32 Version: 7.00.9466
CodeBase: file:///C:/WINDOWS/assembly/GAC/stdole/7.0.3300.0__b03f5f7f11d50a3a/stdole.dll
OptiBreak
Assembly Version: 3.13.1300.0
Win32 Version: 3.13.1300.0
CodeBase: file:///C:/Jobs/Product/Opti/Opti-Break/OptiBreak/bin/Debug/OptiBreak.EXE
GlassOpt
CodeBase: file:///C:/Jobs/Product/Opti/Opti-Break/OptiBreak/bin/Debug/GlassOpt.DLL
GMConfig
CodeBase: file:///C:/Jobs/Product/Opti/Opti-Break/OptiBreak/bin/Debug/GMConfig.DLL
FeneVision.Opti.ShapeLibMgr
Assembly Version: 10.1.2020.1
Win32 Version: 10.1.2020.1
CodeBase: file:///C:/Jobs/Product/Opti/Opti-Break/OptiBreak/bin/Debug/FeneVision.Opti.ShapeLibMgr.DLL
FtSplashScreen
CodeBase: file:///C:/Jobs/Product/Opti/Opti-Break/OptiBreak/bin/Debug/FtSplashScreen.DLL
GMDBData
CodeBase: file:///C:/Jobs/Product/Opti/Opti-Break/OptiBreak/bin/Debug/GMDBData.DLL
SQLDataAccess
CodeBase: file:///C:/Jobs/Product/Opti/Opti-Break/OptiBreak/bin/Debug/SQLDataAccess.DLL
FeneVision.Translations
Assembly Version: 10.11.6300.0
Win32 Version: 10.11.6300.0
CodeBase: file:///C:/Jobs/Product/Opti/Opti-Break/OptiBreak/bin/Debug/FeneVision.Translations.DLL
Opti.Common
CodeBase: file:///C:/Jobs/Product/Opti/Opti-Break/OptiBreak/bin/Debug/Opti.Common.DLL
System.Transactions
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/System.Transactions/v4.0_4.0.0.0__b77a5c561934e089/System.Transactions.dll
System.EnterpriseServices
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/System.EnterpriseServices/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Numerics
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
System.ServiceModel
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel/v4.0_4.0.0.0__b77a5c561934e089/System.ServiceModel.dll
Microsoft.VisualBasic
Assembly Version: 10.0.0.0
Win32 Version: 12.0.20806.33440 built by: FX45W81RTMREL
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
Microsoft.GeneratedCode
Assembly Version: 1.0.0.0
LaserControl
CodeBase: file:///C:/Jobs/Product/Opti/Opti-Break/OptiBreak/bin/Debug/LaserControl.DLL
GMTracking
CodeBase: file:///C:/Jobs/Product/Opti/Opti-Break/OptiBreak/bin/Debug/GMTracking.DLL
GMReports
CodeBase: file:///C:/Jobs/Product/Opti/Opti-Break/OptiBreak/bin/Debug/GMReports.DLL
GMComponents
CodeBase: file:///C:/Jobs/Product/Opti/Opti-Break/OptiBreak/bin/Debug/GMComponents.DLL
Infragistics2.Win.UltraWinExplorerBar.v11.2
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinExplorerBar.v11.2/11.2.20112.2050__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinExplorerBar.v11.2.dll
SKCLNET
Assembly Version: 4.6.0.4
Win32 Version: 4.6.0.4
CodeBase: file:///C:/Jobs/Product/Opti/Opti-Break/OptiBreak/bin/Debug/SKCLNET.DLL
Microsoft.VisualC
Win32 Version: 12.00.20806.33440 built by: FX45W81RTMREL
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualC/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualC.dll
HeglaXYZ
CodeBase: file:///C:/Jobs/Product/Opti/Opti-Break/OptiBreak/bin/Debug/HeglaXYZ.DLL
Accessibility
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
System.Xaml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Codewise, we pretty much just have some code that fires when the user clicks a node, it loops through all other parent nodes and their children and unchecks them.
I noticed that the AfterDataNodesCollectionPopulated event fires during this loop (and I also noticed that when I scroll it fires again). I've also gathered that if I open the screen, and scroll first, the user no longer has the issue. Once the issue happens once, it doesn't happen again until the screen is reloaded.
Any input or suggestions would be greatly appreciated, thanks!
