Hi
I've enabled drag and drop of data between two UltraWinGrids, using the _SelectionDrag, _DragOver and _DragDrop events.
My problem is that the user first needs to click (mouse down and mouse up) on a row to select it, and then mouse-down again and drag and mouse-up to drop.
Is there a way to "automate" or "force" the selection of the row on the first mouse-down so the user can then already drag to drop?
Mike
e.Layout.Override.SelectTypeRow = SelectType.SingleAutoDrag;
did exactly what I wanted. Thanks for pointing me in the right direction.
SingleAutoDrag:Strategy used when only a single item can be selected and pressing the left button and dragging does not select other items but instead starts dragging the selected item immediately
What is your SelectTypeRow property set to? And what are you using for CellClickAction? I think you should be able to find a combiation of these two properties that does what you want.
