435
UltraCalcException when using UltraCalcManager in UltraWinGrid
we discovered a problem with the UltraCalcManager in one of our projects.
The error will be raised in this configuration combination:
  • Add row available
  • UltraCalcManager bound to the UltraWinGrid
  • At least one summary at band level > 0
Steps for reproducing the error:
Select the AddNew Row (via Rowselector).
Hit the ESC Button one time
Point where the exception will be raised:
Thanks in advance,
NESTLÉ
UltraCalcException.zip
  • 48586
    Hello ,
    Thank you for the provided sample, I’ve reviewed it and as a quick workaround I could suggest you to set CalcFrequency to Asynchronous. However I’ve created support ticket in our issue tracing system for you, in order to investigate this further. Case id is CAS-137612-K8X3K1, and I will update you for the progress of my findings via the case as soon I have more information for you.
