355
Deployment Issue with *.isl file
Hello Infragistics Gurus,
I am trying to publish a program I have that makes use of the file, VS2010b.isl.  I am able to run the program just fine in VB2102 but when I publish it, I get the error listed at the end of this file.
I did see a similar problem listed here:
http://es.infragistics.com/community/forums/t/19745.aspx
My code has the file included in the project, the build action set as content, and the copy to output directory option set to copy if newer.
My Main_Load function has the following line included in it:
Infragistics.Win.AppStyling.StyleManager.Load("VS2010b.isl")
In fact, if I open the resources folder once it's published, there is a file called VS2010b.isl.deploy.  I am also able to click the application files folder and see the file and that it is set to "Include (Auto)", the download group is set to Required and the Hash is set to include.  It's probably worth noting that some of the other resources that are included in my references aren't on this list but I haven't set them to content yet and, I'm assuming the issue I'm seeing with the *.isl file can be applied to those files as well.
I'm sure this is probably a relatively easy fix but I don't know how to go about it and I'm about out of ideas as to how to proceed forward.  Any help you can give me would be greatly appreciated.  Thanks!
Below is the error:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.IO.FileNotFoundException: Could not find file 'C:\Users\JBrookley\AppData\Local\Apps\2.0\RVMHO4H5.78W\QHHBQ66B.CPJ\kavl..tion_b0352b5628df4830_0001.0000_202617774d44bbfd\VS2010b.isl'.
File name: 'C:\Users\JBrookley\AppData\Local\Apps\2.0\RVMHO4H5.78W\QHHBQ66B.CPJ\kavl..tion_b0352b5628df4830_0001.0000_202617774d44bbfd\VS2010b.isl'
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
at Infragistics.Win.AppStyling.StyleManager.Load(String fileName, Boolean validate, String styleLibraryName)
at Infragistics.Win.AppStyling.StyleManager.Load(String fileName)
at Kavlico_Calibration_M3_V1_0.KavCalWizard.Main_Load(Object sender, EventArgs e)
at System.EventHandler.Invoke(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.0.30319.18063 built by: FX45RTMGDR
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
Kavlico Calibration M3 V1.0
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Users/JBrookley/AppData/Local/Apps/2.0/RVMHO4H5.78W/QHHBQ66B.CPJ/kavl..tion_b0352b5628df4830_0001.0000_202617774d44bbfd/Kavlico%20Calibration%20M3%20V1.0.exe
Microsoft.VisualBasic
Assembly Version: 10.0.0.0
Win32 Version: 11.0.50709.17929 built by: FX45RTMREL
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
Win32 Version: 4.0.30319.18034 built by: FX45RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Core
Win32 Version: 4.0.30319.17929 built by: FX45RTMREL
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
Win32 Version: 4.0.30319.18036 built by: FX45RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
Win32 Version: 4.0.30319.18021 built by: FX45RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Configuration
Win32 Version: 4.0.30319.18060 built by: FX45RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Runtime.Remoting
Win32 Version: 4.0.30319.34108 built by: FX45W81RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
DigiTalk
Assembly Version: 1.5.1.0
Win32 Version: 1.5.1.0
CodeBase: file:///C:/Users/JBrookley/AppData/Local/Apps/2.0/RVMHO4H5.78W/QHHBQ66B.CPJ/kavl..tion_b0352b5628df4830_0001.0000_202617774d44bbfd/DigiTalk.DLL
Infragistics4.Win.UltraWinToolbars.v13.1
Assembly Version: 13.1.20131.2027
Win32 Version: 13.1.20131.2027
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Infragistics4.Win.UltraWinToolbars.v13.1/v4.0_13.1.20131.2027__7dd5c3163f2cd0cb/Infragistics4.Win.UltraWinToolbars.v13.1.dll
Infragistics4.Shared.v13.1
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Infragistics4.Shared.v13.1/v4.0_13.1.20131.2027__7dd5c3163f2cd0cb/Infragistics4.Shared.v13.1.dll
Infragistics4.Win.v13.1
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Infragistics4.Win.v13.1/v4.0_13.1.20131.2027__7dd5c3163f2cd0cb/Infragistics4.Win.v13.1.dll
UIAutomationProvider
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/UIAutomationProvider/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll
Infragistics4.Win.UltraWinGrid.v13.1
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Infragistics4.Win.UltraWinGrid.v13.1/v4.0_13.1.20131.2027__7dd5c3163f2cd0cb/Infragistics4.Win.UltraWinGrid.v13.1.dll
Infragistics4.Win.Misc.v13.1
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Infragistics4.Win.Misc.v13.1/v4.0_13.1.20131.2027__7dd5c3163f2cd0cb/Infragistics4.Win.Misc.v13.1.dll
Infragistics4.Win.UltraWinDataSource.v13.1
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Infragistics4.Win.UltraWinDataSource.v13.1/v4.0_13.1.20131.2027__7dd5c3163f2cd0cb/Infragistics4.Win.UltraWinDataSource.v13.1.dll
Accessibility
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
Infragistics.License
Assembly Version: 1.0.5005.10
Win32 Version: 1.0.5005.10
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Infragistics.License/1.0.5005.10__7dd5c3163f2cd0cb/Infragistics.License.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
