265
Field Chooser Customisation
 I've been playing with the FieldChooser of the UltraWinGrid and need to be able to customise it a little.
 Currenly i have a grid bound to an sql table and all the columns are grouped under common headings like so:
 Grouped Columns
Within the field chooser i need to do the following:
  1. Remove all group objects (Client Group Details) from the field chooser
  2. Have the items in the same order as the table.
  3. Have a select/deselect all button
For the second issue, i know there is the ColumnChooserControl.ColumnDisplayOrder field.. but it doesn't seem to be exactly the same as the columns when i set it to SameAsGrid.. Maybe this is because i've re-arranged the columns in the UltraGrid Designer??
 To be able to do what i'm asking, would i need to make a custom field chooser form? or is there a way i could add these things in myself with the automatic field chooser?
Thanks for your help,
Craig
