I'm facing a strange problem. We have a large solution which creates various documents like polices and invoices with Infragistics.Documents.Reports. Classes have been build to produce these documents and there's also a class to handle the content. It's pretty straightforward. A new report is created and text is being added with AddContent and sometimes tables are used. The reports are allways published to pdf files.
Now for the problem: very sporadic a space appears in de text. It appears at different locations and on different layouts. However, it only seems to happen when i use a table. If i see the problem occur and generate the same document again, most of the time the space is gone.
Can you point me in a direction what to try or what to change? I can provide examples and/or send you the classes but would prefer to do that in a secure environment since it contains some private information.
We're using 13.2.
Looking forward to hear from you.Kind regards,Jacob
Hi Jacob,
Thank you for contacting Infragistics Developer Support.
I have created a private case in order to investigate the issue. Its number is CAS-136568-T0H8P6. I will provide you with assistance for this issue through it. You can view your active cases by going to Account – Support Activity – Active Cases.
