I've often grouped data, but now I need subtotals at the grouped level - which I've never done. In addition, some of the fields are calculated (percent), whereas others are just summed up for the rows in the group.
I figure that there's either a way to 1) insert a summary row (or have it inserted as part of the grouping function), and then specify sum as the operation for most of the columns, and then do percentage operations against others for the percentage columns (which would mean an operation against two other columns to calculate the percent).
or 2) I figure you're going to tell me to iterate through all rows within the group (which I don't know how to do - I've only iterated an entire ungrouped grid, I don't know about trapping the group break etc.), and then add the values up into variables, then insert the row with these calculated variables into the grid at each group break (which I don't know how to do either), as well as then adding a grand total line.
I am hoping that the grid has some abilities that will let me do something similar to scenario (1) - where it'll keep track of all of these numbers for me (and let me specify sum, avg, etc. as operations to perform) and it can automatically break and subtotal at the group breaks. But if not, I'll iterate, sum, calculate, and add lines - whatever works.
What's the easiest way (in VB.NET) to accomplish this?
Thanks!
Hi Mark,
WinGrid doesn't have any pivot functionality. It's a data grid, so it shows the data in the structure defined in the data source.
If you want to pivot so that columns are rows and rows are column in the WinGrid, you would have to bind the grid to a data source where your data is structured that way.
Another option to consider would be to use UltraPivotGrid which supports pivoting similar to Excel. But the two controls are very different.
Looking at the example you provided, can you provide an example where you pivot the data and show the 4 dates as columns.
I am just checking about the progress of this issue. Let me know if you need my further assistance on this issue.
Thank you for contacting Infragistics Developer Support.
What you could do in order to calculate the percentage summaries is to use the UltraCalcManager. This component lets you to calculate complicated formulas for your summaries while you only need to specify the formula that the UltraCalcManager should use. For more information on custom formulas please visit this link:
http://help.infragistics.com/Doc/WinForms/2014.1/CLR4.0/?page=WinCalcManager_Formula_and_Reference_Guide.html
As for how to insert the summaries, if you want them only when the data is grouped you could use the InitializeRowsCollection event of the grid and check if the grid has GroupByRows. Otherwise you could use the InitialzeLayout event. To add the summaries themselves you could use code like:
UltraGrid1.DisplayLayout.Bands(0).Summaries.Add()
I have attached a sample in VB.Net, which demonstrates my suggestions.
Please let me know if you have any additional questions.
