Hello all,
We converted client project "vs2010 and infragistics v9.1" to vs 2012 with the same dlls. But only ultrawingrid style doesn't work.
Can anybody help us?
Nurcan.
Hi Nurcan,
I am checking if you manage to upgrade your project successfully.
Are you using AppStylist ,Presets, or you are loading some other layouts runtime. Check that you have applied all previously set styling’s and you set all properties.
Hi Didi,
Target framework .NET 3.5
It's not getting error, just ultragrid style apperance is classic windows grid style
Nurcan
Can you check the target framework of the new project and let me know what kind of errors did you get. Did you use project upgrade utility?
