Hi allI have a little strange problem:On my notebook (Windows 8, 1920x1080) not all the text of my explorerbar items are shown,as you can see in the attached picture.It does not make any difference how wide the explorerbar is.Thanks and kind regardsFrank Uray
I am just checking about the progress of this issue. Let me know If anyting that I could do for you regarding this matter?
In order to narrow if it is something related to some setting of your solution file or project file or form, I suggest you to try to reproduce this issue in separate from in the same project and try to reproduce the issue in another project in same solution. So if you are able to reproduce the issue in the same project and not in the other then the issue is related to something of your project settings and etc. On this why you will have direction where you should search for the root of the issue.
I hope that this will helps you.
Hi HristoThank you for your message.Well, the issue is still there and I have no plan why and how to find out whats the problem ...
Best regardsFrank Uray
I am just checking about the progress of this issue. Let me know If you need any further assistance on this issue?
The first thing that is on my mind is that maybe you have applied IUIElementcreationfilter or IUIElementDrawFilter to your explorer bar. Second thing is if you have adjusted TextRenderingMode property of the ExplorerBar or maybe it is something of the build settings that you have managed for your real application.
