Greetings,
For an application I need to display 24x24 pixel Icons next to each of the captions of the ribbon tabs. But when I set the Settings.Appereance.Image property of the RibbonTab to a image of this size, the image is scaled down to 16x16 pixels.
I've also tried to increase the height of the tab caption area by setting a bigger font size, but the images are still getting scaled down.
Is there a possibility to set the size of the image displayed next to the caption of the tab? I am using WinToolbars 8.1 .
The ribbon tab image sizes and the small tool image sizes are controlled with that same property, so there is no way to make them different sizes. You can submit a feature request to have new properties added to control these separately: http://devcenter.infragistics.com/Protected/RequestFeature.aspx.
As far as hiding images on the small tools, you should be able to do that by not settings any Images on the AppearancesSmall property of the InstanceProps or SharedProps of the tool.
Thank you for the quick answer. I tried setting the ImageSizeSmall Property to a 24x24 size and the images next to the tabs have the right size now. But now the small images for the tools in the ribbon, which are displayed when there is not enough space to show the large ones, are of 24x24 size, too, which I don't want.
Is there any possibility to set the size of the tab caption Images independently from the size of the small images of the ribbon tools. It would also be acceptable to disable the display of the small tool images.
You can set the ImageSizeSmall on the UltraToolbarsManager to control this size. There is also an ImageSizeLarge for the size of images in large sized ribbon tools.
