In the main form, when the form load I created a new form and added it to WinTabbedMdi tab.
How to set this form as deafult home page tab (locked tab) without close, drag drop...?
It works perfect! Thank you so much.
There is also an "AllowDrag" property that is also in the Settings. You could just as well use that property.
There is a property for preventing the closing of a tab.
Try something like this:
ultraTabbedMdiManager1.TabGroups[0].Tabs[0].Settings.AllowClose = DefaultableBoolean.False;
As for preventing the dragging of a tab, you can handle the TabDragging event of the UltraTabbedMdiManager and cancel the event after testing for the tab that you want to be stationary.
Something like this:
private void ultraTabbedMdiManager1_TabDragging(object sender, Infragistics.Win.UltraWinTabbedMdi.CancelableMdiTabEventArgs e)
if (e.Tab.Index == 0)
e.Cancel = true;
Let me know if that works for you.
Thank you for your response.
Whats I want is how to make the (first) tab persistent,means that it can not close, while others tab can close.
You can see an example here: https://www.devexpress.com/Support/Center/Example/Details/E2331
I'm not sure that I understand what you want to do. You can set a tab to be the Active tab by calling the Activate method on it. So, you could do something like this:
ultraTabbedMdiManager1.MdiParent.MdiChildren[0].Activate();
Does that give you what you want?
