So I have a winform application that is being used by about 100 people across 5 remote desktop servers 24 hours a day for the last few years.In that time I have seen this problem a handful of times but it seems to be happening more often to one user now.Typically I see this with users with multiple monitors.
In this case I had the user log out of the system, log back on and follow all the steps that led to the bug the first time but it is not reproducible for him.It seems to affect EVERY combo box in the entire application (and there are lots of screens).
I am using appstyling I'm not sure if that has anything to do with it. I have attached a screenshot.. it almost looks like the combobox is sizing to a negative width??
I have no idea where to start tracking this down but any suggestions are welcome!
Hello ,
I’ve created support ticket for you in our Issue tracing system, its id is CAS-140937-G8J6L6 and you could view it under “Support Activity ” in your account:
https://es.infragistics.com/my-account/support-activity
So please add zip of your sample to the mentioned case in order to continue with the investigation of this issue.
Thank you for your collaboration.
I would rather not post the code publicly and unless I misunderstand something this is what you are requesting.
Can I send it to you directly somehow?
Greg
You should zip your files, then when you press "Reply", go to "Option" tab and press "Add/Update" button -> "Choose File", then navigate to your files and press "Save".
I am waiting for your details.
After many hours I have managed to create a stripped down stand alone version of my application that still reproduces the bug.
Every time I can get it to display the drop down combo on the wrong monitor. The narrow combobox bug I think is related but does not reproduce every time.
How can I submit the file for someone to look at? I would prefer not to post it publicly.
Update: This is still happening with the 2014.1 Controls.
This last time it happened when a user was connected to remote desktop with 1 screen then disconnected and reconnected with two screens.Interestingly, when I dragged the window to the other screen the combobox dropdown popped up on the wrong screen!
I think this may be a reproducible bug.
