My first Bar Chart in Ultrachart and I'm having problem.
This is the result I get from this table:
year Total Assets Total Revenue Total Liabilities Total Expenditures2010 85411648.00 57848779.00 11933949.00 60057828.002011 88245533.00 60372377.00 13348894.00 60482052.002012 85411648.00 57848779.00 11933949.00 60057828.002013 88245533.00 60372377.00 13348894.00 60482052.00
How can I change the Legend to reflect the column "YEAR" and remove the text "ROW#" underneath every columns?
My code:
UltraChart ucFinancialChart1 = new UltraChart();ucFinancialChart1.Data.DataSource = financialData;ucFinancialChart1.Axis.Y.RangeType = Infragistics.UltraChart.Shared.Styles.AxisRangeType.Custom;ucFinancialChart1.Axis.Y.RangeMax = 100000000;ucFinancialChart1.Axis.Y.RangeMin = 0;ucFinancialChart1.ColorModel.ColorBegin = System.Drawing.Color.Pink;ucFinancialChart1.ColorModel.ColorBegin = System.Drawing.Color.DarkRed;ucFinancialChart1.ColorModel.ModelStyle = Infragistics.UltraChart.Shared.Styles.ColorModels.CustomLinear;ucFinancialChart1.Border.Thickness = 0;ucFinancialChart1.Legend.Visible = true;ucFinancialChart1.Legend.Location = Infragistics.UltraChart.Shared.Styles.LegendLocation.Bottom;ucFinancialChart1.Legend.SpanPercentage = 35;ucFinancialChart1.ChartType = Infragistics.UltraChart.Shared.Styles.ChartType.ColumnChart;ucFinancialChart1.Width = new Unit(600, UnitType.Pixel);ucFinancialChart1.Height = new Unit(600, UnitType.Pixel);ucFinancialChart1.Data.IncludeColumn(0, false); ucFinancialChart1.Data.SwapRowsAndColumns = true;ucFinancialChart1.Data.DataBind();
Thanks for your response. I'm glad to hear that your issue is solved.
If you have any questions, feel free to write us
Thanks for the reply.
The problem came from bad data.
The "YEAR" field was set as an INT and should have been a varchar.
Problem solved.
Resolved.
Hello Roger,
There are different approaches to solve this task, depending of your scenario. Here are few possible options:
Option 1: You could choose one of the options in DataAssociation. For example:
ultraChart1.Legend.DataAssociation = Infragistics.UltraChart.Shared.Styles.ChartTypeData.ColumnData;
Option 2: You could use combination of these settings:
ultraChart1.Data.UseRowLabelsColumn =true;
ultraChart1.Data.RowLabelsColumn = 0;
Option 3: If you have composite chart (composite legend) then you could specify these settings through the layers . For example:
CompositeLegend m_ChartLegend = new CompositeLegend();
ColumnLayer.LegendItem = LegendItemType.Series;
LineLayer.LegendItem = LegendItemType.Series;
m_ChartLegend.ChartLayers.Add(ColumnLayer);
m_ChartLegend.ChartLayers.Add(LineLayer);
m_ChartLegend.BoundsMeasureType = MeasureType.Percentage;
m_ChartLegend.Bounds = new Rectangle(1, 10, 18, 20);
area.BoundsMeasureType = MeasureType.Percentage;
area.Bounds = new Rectangle(25, 10, 74, 90);
m_ChartLegend.PE.ElementType = PaintElementType.Gradient;
m_ChartLegend.PE.FillGradientStyle = GradientStyle.Circular;
m_ChartLegend.PE.Fill = Color.Yellow;
m_ChartLegend.PE.FillStopColor = Color.Orange;
m_ChartLegend.Border.CornerRadius = 10;
m_ChartLegend.Border.Thickness = 0;
m_ChartLegend.LabelStyle.FontSizeBestFit = true;
ultraChart1.CompositeChart.Legends.Add(m_ChartLegend);
