70
UltraCalendarCombo date keeps reverting back
Version WinForms 8.3.20083.2059
I don't know when this started, but if you type in the Date Box and tab out, the date reverts back to whatever was in the box at the time you entered it.  If you select from the pop up calendar, you're ok, but typing, DOES NOT WORK.  All I can tell is at the time it's typed, the VALUE never changes to what's typed.  For instance, we have a date for payment that defaults to today's date of 02/24/14.  If you change the 24 to 22, then hit tab, it changes back to 24.  if you click the drop down arrow, pop up the calendar and select the 22nd, it will stay.
I appreciate any help resolving this.
  • 18495
    Suggested Answer
    Hello Andural,
    Thank you for contacting Infragistics.
    The version of NetAdvantage you are using is no longer being maintained, but there is a more recent Service Release available for it.  I would suggest installing the most recent Service Release for NetAdvantage 2008 Volume 3 to see if that resolves the issue.  If that doesn't resolve the issue then you will need to upgrade to the newest volume of our Windows Forms controls since the issue does not seem to occur with 2013 Volume 2.
