I am using vs2012 ultimate and infragistcs 13.1. I am trying to use coded UI tests for our win application automation. Is ultraTree not supported by CodedUI?
I got following error message:
Test Name: CodedUITestMethod1Test FullName: Avionte.Suite.Test.Win.CodedUITestProject.CodedUITest1.CodedUITestMethod1Test Source: c:\Workspace\Avionte\Suite\task\fault\Avionte.Suite.Test.Win.CodedUITestProject\CodedUITest1.cs : line 27Test Outcome: FailedTest Duration: 0:00:51.0619522
Result Message: Test method Avionte.Suite.Test.Win.CodedUITestProject.CodedUITest1.CodedUITestMethod1 threw exception: Microsoft.VisualStudio.TestTools.UITest.Extension.UITestControlNotFoundException: Unable to find the top level element of the control ---> Microsoft.VisualStudio.TestTools.UITest.Extension.UITestControlNotFoundException: The playback failed to find the control with the given search properties. Additional Details: TechnologyName: 'MSAA'ControlType: 'Window'Name: 'Avionte | Start Page'ClassName: 'WindowsForms10.Window' ---> System.Runtime.InteropServices.COMException: Error HRESULT E_FAIL has been returned from a call to a COM component.Result StackTrace: at Microsoft.VisualStudio.TestTools.UITest.Playback.Engine.IRPFPlayback.FindAllScreenElements(IScreenElement pScreenElementStart, String bstrQueryId, Object& pvarResKeys, Int32 cResKeys, Int32 nMaxDepth, Object[]& foundDescendants) at Microsoft.VisualStudio.TestTools.UITest.Playback.ScreenElement.FindTopLevelWindowHelper(String queryId) at Microsoft.VisualStudio.TestTools.UITest.Playback.ScreenElement.FindFromPartialQueryId(String queryId, Boolean resetSkipStep) at Microsoft.VisualStudio.TestTools.UITesting.UITestControl..ctor(String queryId) --- End of inner exception stack trace --- at Microsoft.VisualStudio.TestTools.UITesting.Playback.MapControlNotFoundException(COMException ex, IPlaybackContext context) at Microsoft.VisualStudio.TestTools.UITesting.Playback.MapAndThrowComException(COMException innerException, IPlaybackContext context) at Microsoft.VisualStudio.TestTools.UITesting.Playback.MapAndThrowException(SystemException exception, IPlaybackContext context) at Microsoft.VisualStudio.TestTools.UITesting.Playback.MapAndThrowException(SystemException exception, String queryId) at Microsoft.VisualStudio.TestTools.UITesting.UITestControl..ctor(String queryId) at Microsoft.VisualStudio.TestTools.UITesting.SearchHelper.SearchTopLevelWindow(ISearchArgument topLevelSearchArg, String topLevelElementQueryId) at Microsoft.VisualStudio.TestTools.UITesting.SearchHelper.SearchUsingMultipleTitles(ISearchArgument topLevelSearchArg, QueryId topLevelQueryId, IList`1 windowTitles) --- End of inner exception stack trace --- at Microsoft.VisualStudio.TestTools.UITesting.SearchHelper.SearchUsingMultipleTitles(ISearchArgument topLevelSearchArg, QueryId topLevelQueryId, IList`1 windowTitles) at Microsoft.VisualStudio.TestTools.UITesting.SearchHelper.GetTitleUpdatedTopLevelWindow(ISearchArgument topLevelSearchArg, String queryId, IList`1 windowTitles) at Microsoft.VisualStudio.TestTools.UITesting.SearchHelper.GetTopLevelElement(Boolean useCache, Boolean useCacheOnly, ISearchArgument searchArg, IList`1 windowTitles, Int32& timeLeft) at Microsoft.VisualStudio.TestTools.UITesting.SearchHelper.GetElement(Boolean useCache, ISearchArgument searchArg) at Microsoft.VisualStudio.TestTools.UITesting.SearchHelper.Search(ISearchArgument searchArg) at Microsoft.VisualStudio.TestTools.UITesting.UITestControl.FindInternal() at Microsoft.VisualStudio.TestTools.UITesting.UITestControl.<Find>b__d() at Microsoft.VisualStudio.TestTools.UITesting.CodedUITestMethodInvoker.InvokeMethod[T](Func`1 function, UITestControl control, Boolean firePlaybackErrorEvent, Boolean logAsAction) at Microsoft.VisualStudio.TestTools.UITesting.UITestControl.Find() at Microsoft.VisualStudio.TestTools.UITesting.UITestControl.GetPropertyPrivate(String propertyName) at Microsoft.VisualStudio.TestTools.UITesting.UITestControl.<>c__DisplayClass11.<GetProperty>b__10() at Microsoft.VisualStudio.TestTools.UITesting.CodedUITestMethodInvoker.InvokeMethod[T](Func`1 function, UITestControl control, Boolean firePlaybackErrorEvent, Boolean logAsAction) at Microsoft.VisualStudio.TestTools.UITesting.UITestControl.GetProperty(String propertyName) at Microsoft.VisualStudio.TestTools.UITesting.ALUtility.GetTechElementFromUITestControl(UITestControl uiTestControl) at Microsoft.VisualStudio.TestTools.UITesting.ActionExecutorManager.GetActionExecutor(UITestControl uiControl) at Microsoft.VisualStudio.TestTools.UITesting.Mouse.ClickImplementation(UITestControl control, MouseButtons button, ModifierKeys modifierKeys, Point relativeCoordinate) at Microsoft.VisualStudio.TestTools.UITesting.Mouse.<>c__DisplayClass6.<Click>b__5() at Microsoft.VisualStudio.TestTools.UITesting.CodedUITestMethodInvoker.InvokeMethod[T](Func`1 function, UITestControl control, Boolean firePlaybackErrorEvent, Boolean logAsAction) at Microsoft.VisualStudio.TestTools.UITesting.Mouse.Click(UITestControl control, MouseButtons button, ModifierKeys modifierKeys, Point relativeCoordinate) at Microsoft.VisualStudio.TestTools.UITesting.Mouse.Click(UITestControl control, Point relativeCoordinate) at Avionte.Suite.Test.Win.CodedUITestProject.UIMap.RecordedMethod2() in c:\Workspace\Avionte\Suite\task\fault\Avionte.Suite.Test.Win.CodedUITestProject\UIMap.Designer.cs:line 257 at Avionte.Suite.Test.Win.CodedUITestProject.CodedUITest1.CodedUITestMethod1() in c:\Workspace\Avionte\Suite\task\fault\Avionte.Suite.Test.Win.CodedUITestProject\CodedUITest1.cs:line 31
Please let me know.
Thanks,Santosh Newa
Software developer
Hello Santosh,
I try to reproduce your issue using version 13.1 with latest available build - 13.1.20131.2100, but everything seems to works properly. I was able to record and replay the testing script. Could you please tell me what is your current build and if you have older version, please try to upgrade your project with latest available service release. Are you able to upload small sample that reproduce your issue. I`ll be glad to research it for you. In attached video file, you could see one of my tests.
