Is it possible to shrink a grid's width so it will fit the paper size specified during an export?
Your suggested option 3 helped me to solve one of my problems.. Thanks.
Regards
Paul
Hello Kenneth,
I made a test using all available option in Infragistics.Documents.Reports.Report.PageSizes. and for me everything seems to works properly. The PDF files has different size according settings in PageSize
- ultraGridDocumentExporter1.TargetPaperSize = Infragistics.Documents.Reports.Report.PageSizes.Letter;
- ultraGridDocumentExporter1.TargetPaperSize = Infragistics.Documents.Reports.Report.PageSizes. Tabloid;
- ultraGridDocumentExporter1.TargetPaperSize = Infragistics.Documents.Reports.Report.PageSizes.Quarto;
- ultraGridDocumentExporter1.TargetPaperSize = Infragistics.Documents.Reports.Report.PageSizes.A3;
The results are in attached screenshot. Let me know if you have any questions.
Thank you for that sample, however when I run it I find the page is much larger than the letter size than I specified.
I changed the following code in your example:
//ultraGridDocumentExporter1.TargetPaperSize = new Infragistics.Documents.Reports.Report.PageSize(ultraGridPrintDocument1.DefaultPageSettings.PaperSize.Width, ultraGridPrintDocument1.DefaultPageSettings.PaperSize.Height);
It didn't make any difference when I exported to PDF. The page size reported by Adobe Reader was still 23.61 X 28.85 inches.
I have opened a help desk case CAS-131527-Q1W7G8 regarding this issue.
Here is the sample
Thanks for attached code. I try to reproduce the issue using your code, but without success. Could you please tell me what is your current version and do you have any installed service release and which exactly. Meanwhile I made small sample for you. Please take a look on attached sample and video file for more details and if you think that I didn`t reproduce your scenario, feel free to modify this sample to reproduce your issue and revert it back to me. I`ll be glad to research it for you.
