1105
PerformAutoResize method
I'm a little stumped, hoping for some guidance.
In my UltraWinGrid, I'm making use of the PerformAutoResize method after my data load because I like the functionality of having all columns resize themselves to fit the largest cell (and header) value.  However, this often results in extra unused space to the right of the last column.
Browsing through the properties, I stumbled on to the AutoFitStyle property, specifically the "ExtendLastColumn" option which is ideally like to have happen.
However, I can't seem to make the two approaches work.  What I want is a combination of "resize every column with regards to it's cell and header values...except the last column which should disregard it's autosize value and extend to the end of the grid".
Is there a way to do that?  It seems like I can only do one or the other.
Thanks!
Chris Rowland
