I have multiple task with link between them for constraints.Each task is linked to a project.
Sample of my database :
Task1, starts on 01/01/2014, duration of 4 days.Task2, starts when Task1 is over (05/01/2014), duration of 10 dayz. (Link to Task1 with TaskparentId)
Task3, start on 01/01/2014, duration of 15 days.No substask
Task4, start on 01/01/2014, duration of 3 days. 3 subtasks, linked to each other.
I want to see all my task in the same gantt. (See picture top image).And I'd like to see what is the project of tasks.(How to not show week ends ? nobody works week ends here ^^)
But with your control, i created Data with 1 project (to see all my task in the same window), and add all task with parenttask.Many tasks has wierd startdate , duration set to 0 and are "disabled" in the task table. (See picture bottom image).
I don't understand how your control works.
The code for creating Data
foreach (DataRow dr in ds.Tables[0].Rows) { idTache = int.Parse(dr["IdTache"].ToString()); dtDebutTache = Convert.ToDateTime(dr["DteDebutTache"]); dtFinTache = Convert.ToDateTime(dr["DteFinTache"]); duration = dtFinTache - dtDebutTache; if (dr["IdTacheParent"] != null && !string.IsNullOrEmpty(dr["IdTacheParent"].ToString())) { theTasks.Rows.Add(new Object[] { lstGuid[idTache], projectKey, dr["TxtNomTache"].ToString(), dtDebutTache, duration, lstGuid[Convert.ToInt32(dr["IdTacheParent"].ToString())], TaskConstraint.StartNoEarlierThan, null }); } else { theTasks.Rows.Add(new Object[] { lstGuid[idTache], projectKey, dr["TxtNomTache"].ToString(), dtDebutTache, duration, null, TaskConstraint.AsSoonAsPossible, null }); } }
Thanks.
Thanks for Dependancies, but CustomColumn I can't do it. Already read the link u gave me.
But I don't have CustomTaskColumns. For info, i'm on Infragistics2 v10.2
Thanks very much.
EDIT : I updated my version and its ok.
Vincent,
You have to add a Dependency and a Constraint to the Task. So, let's say you have a Task object called teamTask, you could do something like this:
teamTask.Dependencies.Add(budgetTask, TaskDependencyType.FinishToStart);
teamTask.StartDateTime = budgetTask.StartDateTime.AddDays(1);
teamTask.Constraint = TaskConstraint.AsSoonAsPossible;
As for the columns, take a look at this article:
http://help.infragistics.com/doc/WinForms/2013.2/CLR4.0/?page=WinGanttView_Custom_Columns.html
Let me know if you have further questions.
So ... there is some improvment to my tests.
I'm adding Tasks to represent ProjectsI'm adding tasks to represent Projects' Tasks, with a parent link to the project Guid.
Sample :
Tasks.add(myProject,null);
foreach(task in myProject) Task[myProject].Tasks.add(task, myproject);
I have a summary task filled with tasks.
Its OK but i have to set Date start and Date end on each task.But how can we set a task start just after the end of the previous task ?Because if I modify the end date of a task, the next task doesn't change its date start.
How can we add columns ? I looked into all your samples, but nothing s working.
