410
FillSceneGraph
I use FillSceneGraph to display a number of types on the graph. For example if a Y axis value is below some limit i draw a Ellipse around the symbol. I also draw lines and text with no issue EXCEPT for a single Text object that i draw at the bottom  left corner of the graph that contains the date and time the graph was generated.
All  good  so far.
When i print the graph all objects display and print in the correct position  EXCEPT this Text ofject that ends up being drawn in the middle of the graph.
code:
targetLabel = New Infragistics.UltraChart.Core.Primitives.Text()
targetLabel.SetTextString(labelText)
targetLabelSize = Size.Ceiling(Infragistics.UltraChart.Core.Util.Platform.GetLabelSizePixels(targetLabel.GetTextString(), targetLabel.labelStyle))
targetLabel.bounds = New Rectangle(5, UltraChart1.Height - targetLabelSize.Height - 5, targetLabelSize.Width, targetLabelSize.Height)
e.SceneGraph.Add(targetLabel)
