675
DataSource Binding is to long
 I have a problem with DataSource Binding a dataSet to the grid
For certain project it takes between 2 or 3 minutes to bind de data to the grid
I Prepare by programmation the data into 2 dataTable that are in a DataSet. this operation is very fast
Once my dataset is ready I bind It into the grid.Everything works fine but for certain project the binding it is to long.
Is there someting I can do to optimise this?
This is some code to explain how I structure my DataTable and Dataset
Private Sub CreateGridStructure()
CreateRootTable() ' Create Column for the rootTable
CreateSubCategoryTable() ' Create Column for the subCategory Table
m_DataSetRoot.Tables.Add(m_tblroot) ' Addind the rootTable into the DataSet
m_DataSetRoot.Tables.Add(m_tblSubCategory) ' Adding the subCategoryTable into the DataSet
Dim rel As DataRelation
' Create the relation between the 2 Datatablerel = New DataRelation(RELATION_NAME_SUB_CATEGORY, m_DataSetRoot.Tables("Root").Columns(COL_NAME_PECLEUNIK_PHASE_CATEGORY), m_DataSetRoot.Tables("SubCategory").Columns(COL_NAME_PECLEUNIK_PHASE_CATEGORY), False)
m_DataSetRoot.Relations.Add(rel)
m_DataSetRoot.AcceptChanges()
End Sub
 Thanks in advance
