440
BUG :( since 13.2 latest service release ( 2010)
Hi
I have a problem with the following code in 13.2.2010 excel ( VS 2010 , .NET 4):
import of xlsx file ( no change in xlsx/C# file before the update)
Workbook workBookImport = Workbook.Load(AppDomain.CurrentDomain.BaseDirectory + "Fiche_Technique_Client_template.xlsx", false);
var ms = new MemoryStream();
workBookImport.Save(ms);
MemoryStream msClone = DeepClone(ms);
_wbk = Workbook.Load(msClone); // Exception here *1
public T DeepClone(T obj)
using (var ms = new MemoryStream())
var formatter = new BinaryFormatter();
formatter.Serialize(ms, obj);
ms.Position = 0;
return (T)formatter.Deserialize(ms);
I have and exception :
08:27 : qua.a : Export Excel
The margins must be between 0 and 100.
Parameter name : value
La valeur réelle était 1,96850393700787E+16.
Infragistics4.Documents.Excel.v13.2
Void set_LeftMargin(Double)
à Infragistics.Documents.Excel.PrintOptions.set_LeftMargin(Double value)
à Infragistics.Documents.Excel.Serialization.Excel2007.XLSX.PartManagers.ObjectModelWorksheetPartManager.LoadPageMarginsElement(XmlPartManagerBase partManager)
à Infragistics.Documents.OfficeOpenXml.Core.XmlReadManager.TryLoadNormalElement(QualifiedNameInfo elementName, String strictQualifiedName, Int32 currentChildIndex)
à Infragistics.Documents.OfficeOpenXml.Core.XmlReadManager.LoadChildElementsHelper(Int32 currentChildIndex, AlternateContentStatus alternateContentStatus)
à Infragistics.Documents.OfficeOpenXml.Core.PartManagers.XmlPartManagerBase.LoadCore()
à Infragistics.Documents.Excel.Serialization.Excel2007.XLSX.PartManagers.ObjectModelWorksheetPartManager.LoadCore()
à Infragistics.Documents.OfficeOpenXml.Core.PartManagers.XmlPartManagerBase.Load()
à Infragistics.Documents.OfficeOpenXml.Core.OfficeDocumentManager.LoadPart(IPackagePart part)
à Infragistics.Documents.OfficeOpenXml.Core.OfficeDocumentManager.LoadPartRelationships(IPackagePart sourcePart, PartManagerBase sourcePartManagerPrototype, IEnumerable`1 relationships, Boolean hasSourcePartBeenLoaded, Boolean& wereRelationshipsSkipped)
à Infragistics.Documents.Excel.Serialization.Excel2007.XLSX.ObjectModelExcelDocumentManager.LoadCore()
à Infragistics.Documents.Excel.Serialization.WorkbookLoadManagerExcel2007.LoadCore()
à Infragistics.Documents.Excel.Serialization.WorkbookLoadManager.Load()
à Infragistics.Documents.Excel.Workbook.LoadXLSXFile(Workbook workbook, Stream stream, IPackageFactory packageFactory, Boolean verifyExcel2007Xml)
à Infragistics.Documents.Excel.Workbook.LoadHelper(Stream stream, WorkbookFormat format, String parameterName, IPackageFactory packageFactory, Boolean verifyExcel2007Xml)
à Infragistics.Documents.Excel.Workbook.Load(Stream stream, IPackageFactory packageFactory, Boolean verifyExcel2007Xml)
à DecisioModules.Modules.Export.ExportDossierExcel..ctor(DecisioEntities db, Boolean export, MainForm mainFrm) dans C:\DECISIO\V3.1\DecisioModules\Modules\Export\ExportDossierExcel.cs:ligne 76
à DecisioModules.MainForm.GrilleAction(String s) dans C:\DECISIO\V3.1\DecisioModules\RibbonCommand.cs:ligne 618
à DecisioModules.MainForm.ruban_ToolClickExtern(Object sender, ToolClickEventArgs e) dans C:\DECISIO\V3.1\DecisioModules\RibbonCommand.cs:ligne 266
à DecisioModules.MainForm.ruban_ToolClick(Object sender, ToolClickEventArgs e) dans C:\DECISIO\V3.1\DecisioModules\MainForm.cs:ligne 453
I added Xlsx file if you could try it
Fiche_Technique_Client_template.zip
