Hi
Make it simple...
I've a winform application with grid, dropdown...
I just want to know what is the easiest and fastest way to make my application in French ?
currently, it is in english by default, so, how to change that behavior in a quick and easy way ?
PS: I've search over the forum but found nothing simple explaning how to simply switch from one language to another (and for the whole application)
Hello Etienne,
Maybe you are right .... or maybe not :) In a different languages the words has different length and sometimes, you need to modify the size of controls.
Let me know if you have any further questions related with Infragistics controls
Regards
I will be able to deal with that...
Anyway, I think it sucks the way it is handle.
It could be much more easier to provide XML file with the translation and then, do the needed translation instead
of providing code...
The reply of Stef-IT is absolutely correct. If you have any further questions, feel free to write us.
Thank you so much Stef-IT !
There is lot of way to localise an application
For Infragistics Winforms Control (C#):
this is simple but you have to do all translation. As far I know there is no other langage build in Infragistics for winforms...
ResourceCustomizer customizerWinResource = Infragistics.Win.Resources.Customizer; customizerWinResource .SetCustomizedString("LMSG_ValueConstraint_CannotConvert", "La valeur ne peut pas être convertie en {0}.");
ResourceCustomizer CustomizerWingrid = Infragistics.Win.UltraWinGrid.Resources.Customizer; customizerWingrid .SetCustomizedString("DeleteRowsMessageTitle", "Effacer ligne");
http://help.infragistics.com/Help/Doc/WinForms/2012.1/CLR2.0/HTML/Win_Customizing_Assembly_Resource_Strings.html
http://help.infragistics.com/Help/Doc/WinForms/2012.1/CLR2.0/HTML/Win_Assembly_Resource_Strings.html
In general :
- use resx (not the best way to me)
- Database + xml cache
