1310
Context menu fucntionality
Please tell me how to apply the defaultcontextmenu of the ultradockmanager functionalities, through code
I need to create a custom context menu with ultradockmanager, I need to add Hide, Floating, Autohide, Close etc in the custom contextmenu.
I have created a contextmenu, but unable to achieve this built in functionality.
Looking forward for your reply
  • 53790
    Suggested Answer
    Hello Jeni,
    Maybe one possible solution could be:
    1. The fist step will be to disable default context menu through property: UseDefaultContextMenus = False
    2. The second step is to handle both events : MouseEnterElement and MouseLeaveElement and implement the code below:
    private void ultraDockManager1_MouseEnterElement(object sender, Infragistics.Win.UIElementEventArgs e)
               if (e.Element is TabItemUIElement)
                    e.Element.Control.MouseDown +=new MouseEventHandler(this.OnControlMouseDown);
    private void ultraDockManager1_MouseLeaveElement(object sender, Infragistics.Win.UIElementEventArgs e)
                        e.Element.Control.MouseDown -=new MouseEventHandler(this.OnControlMouseDown);
    private void OnControlMouseDown(object sender, MouseEventArgs e)
             if (e.Button == MouseButtons.Right)
                 ContextMenu menu = new ContextMenu();
                 menu.MenuItems.Add("Test1");
                 menu.MenuItems.Add("Test2");
                 ((Control)sender).ContextMenu = menu;
    By this way the final result will be (see attached screenshot)
    Regards
