225
UltraGridDocumentExporter and ColumnStyle.FormattedText
I am using to  UltraGridDocumentExporter to export Grid contents into a PDF.
This works fine but when the Columnstyle is set to formattedtext these Grid Cells in the  PDF are empty.
Is this a known issue?
Matthias
  • 469350
     Hi Matthias,
        The PDF exporter can't handle all of the possible XML tags that the FormattedText cell can, but it should still export the text as best it can. The cells should not be blank - at worst you should just lose some of the formatting. You should report this to Infragistics Developer Support as a bug and include a small sample project that demonstrates the issue so they can check it out and get it fixed.
         http://devcenter.infragistics.com/Protected/SubmitSupportIssue.Aspx
