425
Wingrid performance when modifying records in a hierarchical data structure
I have a dataset that can have 10+ datatables with data relations between all of them (table 1 which is a parent to table 2 which is a parent to table 3, etc).  I bind it to a wingrid and am able to navigate it by expanding it level by level etc, just fine.  For the most part, I can modify fields in rows in the grid without problem as well.  However, there is a very peculiar case where if I modify a field in the first child row of a particular parent row, and there are at least 8 levels below it, then CPU utilization goes to 100% for a long time.  The more levels below, the longer it takes to where it will never complete.  The activity appears to be in the datasource, i.e. doing a Break All and looking at the stack trace, it is in the area of System.Data.DataView, System.Windows.Forms.RelatedCurrencyManager.ParentManager_CurrentItemChanged etc, but not in anything Infragistics.
Bill
