How can I make the ultrawingrid display the following data:
7 Mantle
8 Berra
8 Dickey
9 Maris
to display like this:
Dickey
In other words I want to suppress identical values in the first column.
Thanks!
Try the MergedCellStyle property on the column. I think that will give you pretty close to what you want.
private void ultraGrid1_InitializeLayout(object sender, Infragistics.Win.UltraWinGrid.InitializeLayoutEventArgs e) { UltraGridLayout layout = e.Layout; UltraGridBand band = layout.Bands[0]; band.Columns["Int32 1"].MergedCellStyle = MergedCellStyle.Always; }
