I have created a custom filter for the UltraMessageBoxManager in order to style the DialogButtons and set the "ShowOutline = false". The problem is that ButtonUIElement doesnt have that property.
Any clue?
#region IUIElementCreationFilter Members public void AfterCreateChildElements(UIElement parent) {
} public bool BeforeCreateChildElements(UIElement parent) { if (parent is MessageBoxUIElement) { Form messagebox_form = ((MessageBoxUIElement)parent).Control.Parent as Form; Point p = new Point(messagebox_form.Owner.Location.X + messagebox_form.Owner.Width / 2 - messagebox_form.Width / 2, messagebox_form.Owner.Location.Y + messagebox_form.Owner.Height / 2 - messagebox_form.Height / 2); messagebox_form.Location = p; } if (parent is ButtonUIElement) {
ButtonUIElement btn = (ButtonUIElement)parent; // here i want to convert ButtonUIElement to UltraButtonBase in order to have access to ShowOutline but the conversion or cast its impossible. } return false; }
I am just checking about the progress of this issue. Let me know If you need any further assistance on this matter?
ShowOutline determines whether an outline is rendered outside the button borders when the button is the default button, this meant that if the button is not default, outline will not be rendered. MessageBoxButtonUIElement has get/set property IsDefaulButton which determines if the button will be rendered as default button. So setting this property to false will produces the same result like setting of ShowOutline to false. Then yours code should be:
if (parent is MessageBoxButtonUIElement)
MessageBoxButtonUIElement button = ((Infragistics.Win.UltraMessageBox.MessageBoxButtonUIElement)(parent));
button.IsDefaultButton = false;
return false;
