Hello out there,
I have a grid with three groups and each group has 2-5 columns each. What I would like to be able to do is have the first column in the first group fixed so that it doesn't scroll out of view. Is it possible to fixed only one column in a group?
Thanks, Kris
I am using Ultrawingrid in that i have two group column that having the fixed header option using pin symbol on group header. The question is how to fixed the group automatically without using the Pin symbol on the header. Please guide me it will help a lot.Thanks in advance.
Ravichandran R
Here's a link to Submit a feature request to Infragistics
Thanks Mike. I had already went the route you had suggested, and for what I am doing that works just fine, but I could see a need to be able to have the ability to lock specific columns in a group. So I might suggust this as an enhancement.
Thanks again. Kris
Hi Kris,
No. If you are using groups, then you can only fix an entire group, not a single column.
Perhaps what you should do is create another group that contains only the one column you want fixed and fix that group?
