2145
Another Gantt question, colouring calender columns.
Hi All,
Sorry to bother you again, got another Gantt question, which I thought would be easy, however it is turning out to be not so.
I have set a MaxRange on the gantt chart. That works fine in that it won't set any tasks beyond that date but what I can't do disabled appearance for the dates after the max range to make it obvious to a user they cannot put any dates there. I would have thought it would do that by default.
I looked for an easy way to do this, but A) there appears to be no property settings for "DatesAfterMaxRange.Appearance" or B) No calendar.Initilize column event that I can use to set the appearance (The header init does not cut it).
If there is something I have not found to do this, then please let me know.
I tried to work around this by using a creation filter which don't seem to do anything (though I know through stepping into the code, that it does hit the change colour line) see below:
Imports Infragistics.Win
Imports Infragistics.Win.Misc
Imports Infragistics.Win.UltraWinGanttView
Imports Infragistics.Win.UltraWinSchedule.TimelineView
Imports Infragistics.Win.UltraWinGanttView.UIElements
Public Class TimelineCreationFilter : Implements IUIElementCreationFilter
    Private appearance As AppearanceBase = Nothing
    Public Sub AfterCreateChildElements(parent As UIElement) Implements IUIElementCreationFilter.AfterCreateChildElements
   'Keep going until the parent is a Task Area UI Element.
    If TypeOf (parent) Is TaskAreaUIElement Then
          Dim TaskAreaElement As TaskAreaUIElement
          Dim TimeSlotElement As TimeSlotUIElement
          TaskAreaElement = parent
          'Get the time slot element
          TimeSlotElement = TaskAreaElement.GetDescendant(GetType(TimeSlotUIElement), gstartdate.AddMonths(gsettings.getSetting("MonthRange")))
          If IsNothing(TimeSlotElement) = False Then
                If IsNothing(Me.appearance) = True Then
                    Me.appearance = New Infragistics.Win.Appearance()
                End If
                 'Colour it grey to show it is outside of the max range.
                 Me.appearance.BackColor = Color.Silver
                 Me.appearance.BorderColor = Color.Black
             End If
         End If
   End Sub
    Public Function BeforeCreateChildElements(parent As UIElement) As Boolean Implements IUIElementCreationFilter.BeforeCreateChildElements
        Return False
End Function
