145
Issue when using UltraComboEditor in application accessed via Ericom
Hello -
We have a .NET 2.0 Windows Forms application using .NetAdvantage 9.2 controls (9.2.20092.2083) that is accessed via Ericom (similar to Citrix).
We have found that when the application is not Maximized and the user clicks the drop down button on an UltraComboEditor a colored box (color varies depending on the server) is drawn on the users desktop.  The size of the box seems to match the size of the window.  This is an MDI application and only happens when the MDI child being used is not maximized in the MDI frame.
Depending on where this box is drawn and how large it is, the potential exists for a user to not be able to access anything on their TaskBar.  Additionally, if they minimize the application with this box on the screen and it is covering the TaskBar and or Start button it is near impossible to access anything else.
A similar issue occurs with UltraTabControl that have tooltips.
I do have a video that illustrates the issues if there is a way to get it to you.
I have created a empty form (no custom code of any kind) except for a few controls, Infragistics controls and standard .NET Controls.  The .NET controls work fine but the Infragistics controls result in the boxes being drawn.  I can also provide the example form.
Any suggestions for addressing this are much appreciated.
Thanks.
- John Mercure
