455
weird rounding or calculation error for a simple formula
I have a calculated column in a grid, the formula is simple: D = A - B  - C
(D being the calculated column)
When the result should add up to zero, I get instead something like this: -2.8421709430404E-14
Is this a bug in the calc manager?
For example these numbers: 217.28 - 37.08 - 180.2 should return 0 but instead return the small scientific number above
EDIT: I am using version 2013.1
