Hi Guys,
Panning Gestures in UltraGrid using Windows 8 and touch screen are not working, with latest Windows patches loaded.
As a sample to ensure it wasn't a problem with my Windows Form application I setup a UltraGrid, set a data source, filled it with dummy data, both horizontal and vertical scroll bars appear, gestures are enabled and touch control is added to the form but the grid does not pan when using panning gestures.
This is in WinForms 13.1
I was pretty sure this was working. It may be a Automatic Windows Update has caused an issue with the way UltraGrid does it?
Anyway, it doesn't work anymore.
The strange thing is you can't even "DRAG" the scroll bars. The only way to get the grid to scroll is actually click in the scroll bar to either side of the thumb. Touching and dragging the thumb doesn't work, doesn't move.
Works fine with a mouse though.
Any ideas?
This issue has been resolved in the latest Service Release as of the date of this post.
No worries. I'll let the client know. I don't believe they will have too much trouble in using 125% on the Surface Pro's via the system change.
That shouldn't affect the Tablet Based app we have created, but will probably make navigating Windows Explorer a little difficult when they need to copy files etc. I'll look into the other option of SetProcessDPIAware if it becomes bothersome for them.
Thanks for figuring out a temporary solution.
We've been debating a fix for a bit but that is a workaround in the meantime. There are other options... the application can add the win32 api call to SetProcessDPIAware via pinvoke but that has pros and cons for an application as well. We are continuing to research the underlying cause with the system information being returned to us with those higher DPI settings and will keep you posted via the bug submitted on your behalf but in the meantime changing the system DPI to 100% or 125% will work or using the SetProcessDPIAware call... not that I'm a fan of either choice but they are options that should be considered and the ramifications of each workaround should be investigated before you decide to use them.
On the Toshiba Kirra set to 165% DPI, changing it to Medium 125% fixes the issue.
Can this be fixed? While changing the DPI is a workaround in the short term, not ideal in the long term.
That's what I mean... change the system DPI from large (150%) to Small (100%) or Medium (125%) and see if it works for you then. Just dropping the resolution isn't what I meant, actually change the DPI setting. It requires a log out of windows to take hold though. The only time I've been able to reproduce this on any device (including the Surface Pro I snagged to test with) was when the DPI was set to 150% as the values we get back from the system ScreenDPI are wrong.
