105
Disabling ultralist items
How can I disable ultralist items? I would like the items to still be visible, but they should be disabled (not clickable) is there a way to do this?
Right now I am using a standard Toolstrip, in which I can disable buttons, but I would like to replace it with an ultralist.
  • 2263
    Unfortunately it doesn't look like the UltraListBar has this the enable/disable functionality you are looking for.  You could use the UltraExplorerBar though and change its Style property to Listbar. The following line of code demonstrates this:
    this.ultraExplorerBar1.Style = Infragistics.Win.UltraWinExplorerBar.UltraExplorerBarStyle.Listbar;
    You can then add groups and items similar to how you add them to the UltraListBar, and you can enable and disable them.  The following code snippet shows how to disable an item
    this.ultraExplorerBar1.Groups[0].Items[0].Settings.Enabled = Infragistics.Win.DefaultableBoolean.False;
    One other plus, if it is of concern, is the UltraExplorerBar supports Application Styling, while the UltraListBar does not.
    Hope that helps.
