635
Problem with UltraWinGrid layout
I have a program that works on several PC, but on one of them (with XP Pro) I have this error when I try to load a grid layout from file:
The system cannot find the file specified. (Exception from HRESULT: 0x80070002)
The function "CaricaLayoutGrid" checks if the layout file exists and in that case exec UltraWinGrid.DisplayLayout.Load
The stack trace is this:
System.IO.FileNotFoundException: Impossibile trovare il file specificato. (Eccezione da HRESULT: 0x80070002)
   in System.ModuleHandle._GetPEKind(Int32& peKind, Int32& machine)
   in System.ModuleHandle.GetPEKind(PortableExecutableKinds& peKind, ImageFileMachine& machine)
   in System.Reflection.Module.GetPEKind(PortableExecutableKinds& peKind, ImageFileMachine& machine)
   in System.Reflection.Assembly.ComputeProcArchIndex()
   in System.Reflection.Assembly.GetName(Boolean copiedName)
   in System.Reflection.Assembly.GetName()
   in Infragistics.Shared.Serialization.Binder.FindType(Assembly assembly, String assemblyName, String typeName)
   in Infragistics.Shared.Serialization.Binder.BindToTypeImpl(String assemblyName, String typeName)
   in Infragistics.Shared.Serialization.Binder.BindToType(String assemblyName, String typeName)
   in Infragistics.Win.Serialization.Binder.BindToType(String assemblyName, String typeName)
   in Infragistics.Win.UltraWinGrid.Serialization.Binder.BindToType(String assemblyName, String typeName)
   in System.Runtime.Serialization.Formatters.Binary.ObjectReader.Bind(String assemblyString, String typeString)
   in System.Runtime.Serialization.Formatters.Binary.ObjectReader.GetType(BinaryAssemblyInfo assemblyInfo, String name)
   in System.Runtime.Serialization.Formatters.Binary.ObjectMap..ctor(String objectName, String[] memberNames, BinaryTypeEnum[] binaryTypeEnumA, Object[] typeInformationA, Int32[] memberAssemIds, ObjectReader objectReader, Int32 objectId, BinaryAssemblyInfo assemblyInfo, SizedArray assemIdToAssemblyTable)
   in System.Runtime.Serialization.Formatters.Binary.__BinaryParser.ReadObjectWithMapTyped(BinaryObjectWithMapTyped record)
   in System.Runtime.Serialization.Formatters.Binary.__BinaryParser.ReadObjectWithMapTyped(BinaryHeaderEnum binaryHeaderEnum)
   in System.Runtime.Serialization.Formatters.Binary.__BinaryParser.Run()
   in System.Runtime.Serialization.Formatters.Binary.ObjectReader.Deserialize(HeaderHandler handler, __BinaryParser serParser, Boolean fCheck, Boolean isCrossAppDomain, IMethodCallMessage methodCallMessage)
   in System.Runtime.Serialization.Formatters.Binary.BinaryFormatter.Deserialize(Stream serializationStream, HeaderHandler handler, Boolean fCheck, Boolean isCrossAppDomain, IMethodCallMessage methodCallMessage)
   in System.Runtime.Serialization.Formatters.Binary.BinaryFormatter.Deserialize(Stream serializationStream)
   in Infragistics.Win.UltraWinGrid.UltraGridLayout.LoadHelper(Stream stream, PropertyCategories propertyCategories, IFormatter formatter)
   in Infragistics.Win.UltraWinGrid.UltraGridLayout.Load(Stream stream, PropertyCategories propertyCategories)
   in Infragistics.Win.UltraWinGrid.UltraGridLayout.Load(Stream stream)
   in MyProgram.frmOrder.CaricaLayoutGrid(UltraGrid grid, String path)
Any idea?
Thank you
