Hi
I have a grid whith a lot of columns, so the last columns are only accessible by scrolling.
My two first columns are "fixed columns".
If I enlarge the second fixed column so that it reaches the end of the space dedicated to the grid , I still see my scrollbar, but cliking on it has no effect and so I cannot see my other columns anymore.
How could I prevent this ? (it is even not possible to make the fixed column smaller once it goes until the end of the space dedicated to the grid)
Verane.
Hello Verane,
If you are using Mike`s idea, you could solve your task for example with the code below:
private void ultraGrid1_AfterColPosChanged(object sender, Infragistics.Win.UltraWinGrid.AfterColPosChangedEventArgs e)
int totalWidth = ultraGrid1.DisplayLayout.Bands[0].Columns.OfType<UltraGridColumn>().Where(p => p.Header.Fixed).Sum(s => s.Width);
if(totalWidth >= ultraGrid1.Width)
e.ColumnHeaders[0].Column.ResetWidth();
Please take a look at the attached sample for more details. Meanwhile You can suggest new product ideas for future versions at <http://ideas.infragistics.com>. There are many benefits to submitting an product idea:
- Direct communication with our product management team regarding your product idea.
- Notifications whenever new information regarding your idea becomes available.
- Ability to vote on your favorite product ideas to let us know which ones are the most important to you. You will have ten votes for this and can change which ideas you are voting for at any time.
- Allow you to shape the future of our products by requesting new controls and products altogether.
- You and other developers can discuss existing product ideas with members of our Product Management team.
Steps to create your idea:
1. Log into the Infragistics Product Idea site at http://ideas.infragistics.com (creating a new login if needed).
2. Navigate to the product / platform channel of your choice (e.g. WPF, Windows Forms, ASP.NET, HTML5 / Ignite UI, iOS / NucliOS, etc.)
3. Add your product idea and be sure to be specific and provide as much detail as possible. Explain the context in which a feature would be used, why it is needed, why it can’t be accomplished today, and who would benefit from it. You can even add screenshots to build a stronger case. Remember that for your suggestion to be successful, you need other members of the community to vote for it. Be convincing!
The Product Idea site puts you in the driver’s seat and allows you to track the progress of your ideas at any time, see how many votes it got, read comments from other developers in the community, and see if someone from the product team has additional questions for you.
Hi Mike,
Thanks for your answer. I could do that but it may be not so easy, you have to check wether the sum of the size of all the fixed columns are too big regarding the space you have for the grid. I would prefer that the grid has an option so that it always leave a little space for not fixed columns.
For me it is more a bug that you still have your scroll bar but moving it has no effect...
Best regards,
Hi Verane,
You could trap the Before/AfterColPosChanged event of the grid. These events fires when the user resizes a column. So you could check to see if the columns are too large and reset them to smaller widths.
