Hi !I want to fill a UltraCombo ("dataSourceExcelSheets") with items via UltraDataSource ("excelSheetCombo") at runtime. The filling of the UltraDataSource will be invoked at runtime via a button event Click.The UltraCombo's DataSource will be set in the InitializeComponent() method this.excelSheetCombo.DataSource = this.dataSourceExcelSheets;Problem:After filling the UltraDataSource it's items will be not shown in the UltraCombo.Therefore I would be grateful for any help.
Kind regards
The Code
using Excel = Microsoft.Office.Interop.Excel; private void buttonImportExcel_Click(object sender, EventArgs e) { Excel.Application excelApp = null; Excel.Workbook workBook = null; Excel.Worksheet workSheet = null; String filename = null; try { this.openFileDialogExcelImport.ShowDialog(); filename = this.openFileDialogExcelImport.FileName; this.filenameLabel.Text = filename; // Neue Excel-Instanz erzeugen excelApp = new Excel.ApplicationClass(); excelApp.Visible = true; workBook = excelApp.Workbooks.Open( filename, ExcelConst.UpdateLinks.DontUpdate, ExcelConst.ReadOnly, ExcelConst.Format.Nothing, "", // Passwort "", // WriteResPasswort ExcelConst.IgnoreReadOnlyRecommended, Microsoft.Office.Interop.Excel.XlPlatform.xlWindows, "", // Trennzeichen ExcelConst.Editable, ExcelConst.DontNotifiy, ExcelConst.Converter.Default, ExcelConst.DontAddToMru, ExcelConst.Local, ExcelConst.CorruptLoad.NormalLoad); if (workBook != null) { for (int i = 0; i < workBook.Sheets.Count; i++) { Excel.Worksheet sheet = (Excel.Worksheet)workBook.Sheets[i + 1]; this.dataSourceExcelSheets.Rows.AddRange(new object[ { new Infragistics.Win.UltraWinDataSource.UltraDataRow(new object[ { ((object)("Nr")), ((object)(((short)(i)))), ((object)("Tabellenname")), ((object)(sheet.Name))})}); } } this.excelSheetCombo.DataBind(); } catch (Exception ex) { // Tabellenblatt entsorgen if (workSheet != null) Marshal.ReleaseComObject(workSheet); // Mappe entsorgen if (workBook != null) Marshal.ReleaseComObject(workBook); // Excel schließen if (excelApp != null) { excelApp.Quit(); Marshal.FinalReleaseComObject(excelApp); } } }
What exactly happens when you drop down the combo? Do you see columns? Do you see anything at all? Are there empty rows or no rows?
Try checking the Rows count on the UltraDataSource an the UltraCombo. You might also try checking the count of the Columns in both the UltraDataSource and the Ultracombo.
This seems to be in the wrong group and might be better served in the WinCombo group
http://forums.labs.infragistics.com/forums/81.aspx
