Hi Viewers'
I've successfully added ultracombo control to a ultragrid control using EditorControl.
when i'm clicking that cell "ultracombo" is opening but the problem is that, the cell also is in editable mode, a user directly type anything in that.... that is the problem.
just i want a user only select "ultracombo" values....
my code..
uGrid_UserDetails.DisplayLayout.Bands[0].Columns["Group"].EditorControl = this.ucombo_Groups_hide;
thanks in advance.
Thank you very much!
If you want to put a dropdown list in a cell, using an editor isn't really the best or most efficient way to do it. Unless you need the EditorControl for some other reason, like you are using a DataFilter or EditorButtons, you'd be better off with using an UltraDropDown and assigning it to the ValueList property of the column.
Here's an article with more info: HOWTO:What is the best way to place a DropDown list in a grid cell?
Anyway, none of that is related to your question, it's just an FYI. Whether you are using an EditorControl or a ValueList, the answer is the same. What you want to do is set the Style of the column to DropDownList.
