275
Get Ultragrid cell values while ultragrid is currently grouped by its column
Hi, I have this Ultragrid that can be group by column. In my code I have to loop through its rows to get/set a specific cell value. My code goes like this:
foreach(var item in MyGrid.Rows)
    if((bool)item.Cells["Check"].Value)
       item.Cells["ItemToBeFilledIn"].Value = MyTextBox.Text;
Everything goes well if it is not grouped. But when I drag a column and group it by itself, there will be an exception message. When I try to debug, I saw that item.Cells is NULL.. Why? How can I get values from that cell?
  • 275
    Verified Answer
    Ok, now I get it. Here's the code I used:
    var allRowsEnumerator = MyGrid.Rows.GetRowEnumerator(GridRowType.DataRow, null, null);
    foreach (UltraGridRow childRow in allRowsEnumerator)
      if((bool)childRow.Cells["Check"].Value)
        childRow.Cells["ItemToBeFilledIn"].Value = MyTextBox.Text;
    That's what I did. But I'm still open for any other suggestion
