190
Changing Data Source Changes Grid's Row Height
I have a tab control with 2 tabs. The first tab contains a summary grid, and the second tab contains a details grid.
When I assign the DataSource property of the Summary grid, the row height of the Summary grid's rows is normal. However, when I set the DataSource of the Details grid, the row height of the Details gridis higher, but about 10 pixels or so.
If I set the data source of the Details grid to the same data source as the Summary grid, then the Details grid's row height is normal. As soon as I set the Details grid's data source to the DetailDataSource, the row height changes.
I can reproduce the problem, and there is no code affecting this.
  • 469350
    Hi Kevin,
    The row height could change based on the data. If one of your cells is multiline or a data type like image or DateTime, then some of the cells in the row might need more height in order to display it. For example, a DateTime column shows a dropdown button, so this can increase the height of the row to make the button fit.
    If you want to force the height of the row to a particular size, then simply set the Height of the Row. You may also need to set the MinHeight.
