Hi thereWe are using Infragistics4.Win.UltraWinExplorerBar.v13.1.20131.2027 in a C# .NET 4.0 WinForms app.When the ExplorerBar Navigation Pane Flyout is displayed the text of the items in the group being displayed is being truncated.We have no code in either the NavigationPaneFlyoutDisplaying or NavigationPaneFlyoutDisplayed event handlers so that is not the problem.Any ideas?I have attached a screenshot of the items in the group which are truncated.Thanks in advanceGeoff
Hi Geoff,
You should be able to prevent this behavior by increasing the NavigationPaneFlyoutSize.Width property to something like 200-300.
Please let me know if this works for you
Hi Jose
Thanks for the reply.
I believe the issue relates to the limitation described here:
http://help.infragistics.com/Help/NetAdvantage/WinForms/2012.2/CLR4.0/html/Infragistics4.Win.UltraWinExplorerBar.v12.2~Infragistics.Win.UltraWinExplorerBar.UltraExplorerBar~NavigationPaneCollapsing_EV.html
I have implemented the solution described at that link and the problem exists if the Dock value of the WinExplorerBar is NOT None.
The problem goes away if the Dock value is set to None but that is not really an option for me
I will continue attempting to work out a solution.
Regards
Geoff
Hello Geoff,
I will be happy to assist you with your inquiry.
I used the information you've provided to reproduce the behavior you're encountering with no success.
I have attached the sample project I used to test this. Please test this project on your PC; whether or not it works correctly may help indicate the nature of this problem.
If the project does not work correctly, this indicates either a problem possibly specific to your environment, or a difference in the DLL versions we are using. My test was performed using version 13.1.20131.2027 in NetAdvantage for Windows Forms 2013 Volume 1.
If the project does show the product feature working correctly, this indicates a possible problem in the code of your application. It will help if you can provide a small, isolated sample application that demonstrates the behavior you are seeing.
Or, if this sample project is not an accurate demonstration of what you're trying to do, please feel free to modify it and send it back, or send a small sample project of your own if you have one.
Please let me know if I can provide any further assistance.
