I have several UltraGrids(12.1) using an .isl style. On only one of the grids, the GroupByBox text has the last letter overlayed by the sort icon. If the column header text is "Description", it's the "n". If the column header text is "PO" it's the "O". All other grids work just fine without any text truncation and they all use the same .isl file. Do you know what would cause this behavior. Very puzzling and frustrating. Thanks.
Ron
Hi Ron,
That sounds like it's a bug and I'd like to try to duplicate it so we can get it fixed.
Are you using one of our isl files? If so, which one? If not, can you post your isl here so we can try it out?
Okay. I found it. In the designer the grid Override>HeaderStyle was set to WindowsXPCommand. I changed it to to Default and everything works fine now.
