645
DataBindings between UltraUIElements and DataRow?
Hi, all,
how does it work the databindings bidirectional between UIElements and one DataRow?
e.g. the Row has three columns (int, string datetime)
(1) Set Value from DataRow to UI
int id = Convert.ToInt32(myRow[0]);
string s = myRow[1].ToString();
DateTime d = Convert.ToDateTime(myRow[2]);
// remove all bindings
ultraCombo1.DataBindings.Clear();
ultraTextEditor1.DataBindings.Clear();
ultraCalendarCombo1.DataBindings.Clear();
// add new bindings
ultraCombo1.DataBindings.Add(new Binding("Text", id.ToString(), ""));
ultraTextEditor1.DataBindings.Add(new Binding("Text", s, "", true, DataSourceUpdateMode.OnValidation));
ultraCalendarCombo1.DataBindings.Add(new Binding("Value", d, "", true, DataSourceUpdateMode.OnValidation));
=> it works!
(2) Set Value from UI to DataRow
But after I change TextBox.Text, oder Datetime, I wish i can also see the changes on myRow...
I have tried these methods, but it does not work...
myRow.BeginEdit();
myRow.AcceptChanges();
myRow.EndEdit();
What's wrong? Many thanks!
